Electric Baseboard Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2012, 01:18 PM   #1
I need to replace a 96", 240 volt, 650 watt electric baseboard heater (no brand name evident) in a rental property. I've looked in stores and on-line and cannot find an equivalent unit--most heaters that long are ~2000 watts. I've got a 15amp circuit breaker on the line and don't know if I can put any heavier load on it. Thus, my questions: Are heaters still made that are equivalent to the one that's in there? If so, any idea where I can find one? If such a unit is not available, do I dare install a 2000 watt unit?
Thanks!
Fitchburg1 is offline   Reply With Quote
Old 09-03-2012, 01:41 PM   #2
Julius793's Avatar
Thanks!
If its a 240v then a 2000w heater is not an issue
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-03-2012, 02:09 PM   #3
Electrical Contractor
kbsparky's Avatar
connect it to 120 Volts, then you'll get 500 watts out of it ...
-KB
Old 09-03-2012, 05:01 PM   #4
amazon and bizrate both have 500w and 750w 240v electric baseboard heaters
Tags
electric heat
Not Enough Hot water in the shower from a 40 Gallon Electric Hot Water Heater. rcake Plumbing 10 06-10-2011 12:20 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Electric baseboard heaters ? ants1929 HVAC 11 03-11-2011 08:23 AM
Baseboard heater under window jhubert Electrical 1 10-07-2009 10:59 PM
Electric Radiant Baseboard and Built-in Bookshelves arobin HVAC 4 07-08-2009 05:42 PM
