Electric Baseboard - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 07:18 PM   #1
electric baseboard
I replaced a six foot baseboard. It has power at wire connections but baseboard does not heat up. There are four wires coming out of the wall plus two grounds. I have the whites connected to each other. and the blacks connected. any Idea what is wrong.
Thank you
mark e hurley is offline   Reply With Quote
Old 01-30-2014, 07:32 PM   #2
joed's Avatar
Rewards Points: 12,036
too many possibilities.
Heater has a switch or thermostat that is off or defective.
Heater is 240 volts and power supply is 120volts.
You hooked it up wrong.
Thermostat on wall is bad.
Heater is defective.
Old 01-30-2014, 07:34 PM   #3
Rewards Points: 6,652
What did the instructions state, that came with the new unit? Also, how many wires go to the thermostat that controls it. Before you replaced it, was the old one working fine?
Old 01-30-2014, 07:53 PM   #4
electricbaseboard
the old one was working. there are four wires going to thermostat
Old 01-30-2014, 09:03 PM   #5
Well if the old one was working, was the thermostat working with the old baseboard heater? How many wires go to the thermostat, how many to the baseboard? If there are only four from the thermostat, that goes to where the baseboard is attached, see the below info.
What are the terminals labeled inside the thermostat? Did you double check to make sure you had the correct wire on the thermostat, connect to the correct terminal on the baseboard?
Old 01-31-2014, 12:28 PM   #6
Rewards Points: 808
Are you reading 240v across the wires that come from the wall? Where is the thermostat located, is it wall mounted or housed within the baseboard? At the other end of the baseboard, is the wire from the element tied to the wire that loops back to the junction box you're splicing in? Is this, in fact a 240v heater with a 240 volt supply?
IslandGuy is offline   Reply With Quote
Old 01-31-2014, 12:39 PM   #7
Rewards Points: 728
open the other end of baseboard you probably have an open splice
carmusic is offline   Reply With Quote
Electric Baseboard Heaters Always On.. volvik Electrical 15 01-23-2013 02:50 PM
1 Electric Baseboard is Out, advice? agentphish Electrical 18 01-05-2013 10:49 AM
Electric baseboard not working secutanudu Electrical 53 01-23-2012 07:34 PM
Electric Radiant Baseboard and Built-in Bookshelves arobin HVAC 4 07-08-2009 06:42 PM
