Electric - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2012, 06:10 PM   #1
electric
can i use extension cord with samsung 22 inch tv
JanDon is offline   Reply With Quote
Old 07-24-2012, 06:13 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Absolutely not. Well, you can, its not like the extension cord police are going to knock on your door. But, in reality, you should never use extension cords to substitute for fixed wiring.
The Following User Says Thank You to stickboy1375 For This Useful Post:
JanDon (07-24-2012)
Old 07-24-2012, 06:25 PM   #3
Rewards Points: 506
Isn't this contradictory to the absolute and entire intended function of extension cords?
jlmran is offline   Reply With Quote
Old 07-24-2012, 06:28 PM   #4
E2 Electrician
No, extension cords are for temporary extension of a circuit, do you plan on moving your tv often? Or do you plan on setting it in place for years to come?
Look at the dangers of them, the rubber insulation wears out easily, causing fires and shocks... they are dangerous by nature, but allowed for temporary uses because they are more opted to be inspected.
Old 07-24-2012, 06:32 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Depends on the gauge of the extension cord. If it's a cheap 18 AWG extension cord 100' long....yea, not a real good idea. 14 Awg 15' long? No problem.
If it's a 'portable' TV....which 22" sounds like it is.....the OP can use all the extension cords he wants.
Old 07-24-2012, 06:32 PM   #6
Rewards Points: 506
Isn't the temporary extension of a circuit a"substitute for fixed wiring"?
Old 07-24-2012, 06:35 PM   #7
E2 Electrician
Absolutely not, its temporary, fixed wiring is permanent.
Old 07-24-2012, 06:38 PM   #8
E2 Electrician
Sure, if he wants to carry his tv out to his gazebo and run a cord to it for the day, I'm down with that, but, if he plans on sitting this in an entertainment center for the next 15 years, i see an issue with it.
Old 07-24-2012, 06:39 PM   #9
Rewards Points: 506
Substitutes can be temporary...can't they?
Old 07-24-2012, 06:41 PM   #10
E2 Electrician
I can't believe we are discussing this, do whatever you want, you are going to anyway.... since you are trying to convince yourself that its safe to anyway..
Im not trying to be rude with this, but lets face it, extension cords are for temporary use, you figure out what temporary is and go with it.
MisterZ (07-24-2012)
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 05:23 PM
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 04:45 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 02:01 PM
