Old 07-15-2012, 11:15 AM   #1
electric
If I run one supply line to gfi, I can put vanity light onto line coming off of gfi. granted that if gfi trips, vanity light will go off aswell. can I supply a second light in ceilng from same load wire feeding gfi and not go off if gfi trips.
tilebusiness is offline   Reply With Quote
Old 07-15-2012, 11:20 AM   #2
J. V.'s Avatar
electric
You only need GFCI protection on the receptacles. Not the lights, unless they are in showers and other areas like that. And that is subjective. But yes. You can feed anything you like from the load side of the GFCI receptacle.
Old 07-15-2012, 01:11 PM   #3
electric
Yes you can have a second light that does not go off if the GFCI receptacle should trip but you would need to run separate wires for it and not share the same load wires as the first light.
The wires for the light that does not go off would be connected to the incoming wires. Match white to white and black to black.
If two wires want to go under one screw, cut a short length (pigtail) of the same color and attach this to the screw. Connect the other end of the pigtail to the two wires in question.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded.
Old 07-15-2012, 01:17 PM   #4
electric
Yes you can have a second light that does not go off if the GFCI should trip but you would need to run separate wires for it and not share the same load wires as the first light.
When figuring out how big the box must be for a GFCI receptacle I suggest counting 4 points for the GFCI unit even though code requires 2 points.
electric versus propane water heater Jeremy Hillary Boob, PhD Appliances 7 01-30-2012 06:23 PM
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 05:45 PM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
