Elecrtical Panel Dangerous??? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2008, 11:43 AM   #1
Ihave the electrical panel for my entire kouse in my spare bedroom. I am wondering if any elctrical panel will emit any sort of dangerous waves I should be concerned with or is this just a myth.Should I cover it and with what would be suggested.Ive worked with metal pretty much my entire life and would prefer to cover it with stainless or aluminum.Or is that just stupid and cover it with wood.A box or cover idea would be appreciated.
Trouble-T is offline   Reply With Quote
Old 09-23-2008, 12:37 PM   #2
joed's Avatar
Rewards Points: 12,376
The box should already be metal.
As for the EMI emmisions, there are many theories on this but I would not be conecerned.
Old 09-23-2008, 12:40 PM   #3
Rewards Points: 126
No concern here either. Why do you ask this question? Are there any issues present?
Old 09-23-2008, 01:04 PM   #4
Registered User
Termite's Avatar
I've never heard of such a thing. Do not modify the panel or its cover in any way whatsoever. You can put a cabinet door over the front of the panel cover, mounted on hinges to the wall. Be sure not to restrict access to the panel or impede the removal of the panel cover.
An aluminum foil hat may shield you from dangerous waves...
Old 09-23-2008, 07:29 PM   #5
electrician
I believe you might have problems secreting milk from your mammary glands.
Silk is offline   Reply With Quote
Old 09-23-2008, 08:01 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
With or without homemade clothes hanger 'rabbit ears' ?
Kyle
Old 09-23-2008, 08:14 PM   #7
Registered User
Termite's Avatar
I prefer my foil hats to be rounded without the ears. Aliens can read your thoughts better if there are ear holes.
Old 09-24-2008, 06:44 AM   #8
Big myth, there is emi that is emitted, but is not enough to bother anything. I guess for the appearance you can put a wood door over it. DO NOT cover it up to where its not readily accessible, and DO NOT put a large object (like a shelf or something) in front of it.
rgsgww is offline   Reply With Quote
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 02:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
