Elec Box Says 20 AMP SPARE?? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-15-2013, 01:08 PM   #1
Do it yourselfer here. I am attempting to install two GFCI exterior outlets in my home. My basement is unfinished so this is pretty easy. I have outlets mounted now all I need to do is wire them up. I have two electrical boxes (one on each end of a ranch style home) that are labeled "20 Amp Spare", however I do not see this labeled in the breaker box as such. What do you think this means and can I simply tap into these electrical boxes for each of my GFCI's ? Thanks so much for the help.
electricamateur is offline   Reply With Quote
Old 07-15-2013, 01:57 PM   #2
Rewards Points: 258
You only need one GFCI as the first outlet in the circuit. There are tools out there to help identify circuits
redman88 is offline   Reply With Quote
Old 07-15-2013, 02:10 PM   #3
Understood about the gfci, I'm probably not going to be putting them on the same circuit because I am installing them on opposite ends of a large ranch so I don't want to run that much wire between the two. Anyways I guess my question is more about the spare. Why would this be done by the electrician? Simply for convenience? How do I know how much of a load I can put on these "spares"?
Old 07-15-2013, 02:16 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
Find the breaker in question and determine what else is on that circuit.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Speedy Petey (07-16-2013)
Old 07-15-2013, 06:55 PM   #5
PoleCat's Avatar
Rewards Points: 1,652
It seems unlikely that anyone would put in a breaker and run wire to a junction box that is not being used. Certainly needs to be scoped out to determine what's up.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 07-16-2013, 05:13 AM   #6
An old Tradesmen
Rewards Points: 8,142
Moved to Electrical forum.
Old 07-16-2013, 06:24 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
I disagree. While not often, this is certainly done. Why would they wrote "20A spare", and not just "spare"?
Old 07-16-2013, 06:26 AM   #8
electricamateur, with help, put a tester on the wire and turn off breakers one by one. You'll find it.
If it is off you may need to trace it physically to see which one it is.
Have you even opened the panel yet? What kind of experience do you have doing electrical work?
Old 07-16-2013, 07:20 AM   #9
Resi EC
Rewards Points: 252
Being a 'spare' it may or may not have a breaker on it.
Some will put a spare in if it would be difficult to get to the panel at a later time.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 07-16-2013, 08:49 AM   #10
Electrical Enthusiast
Rewards Points: 504
I agree. There might just be a few inches of Romex in the panel, with nothing hooked up.
Kyle_in_rure is offline   Reply With Quote
Spare main panel circuits pw5599 Electrical 0 10-30-2011 01:10 AM
Spare cable inside conduit...allowed? newguynet Electrical 1 02-18-2011 09:15 AM
DIY new elec circuits or do I need a pro? tomseeley Electrical 4 03-30-2010 12:02 PM
underwater elec. panel robin power Electrical 33 11-02-2008 04:38 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
