Elec - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2012, 09:00 PM   #1
elec
I'm wireing two lights in my basement on one switch, the power from the box runs to the light first and second light then to switch.how would I wire this up
tjhartman is offline   Reply With Quote
Old 09-09-2012, 10:20 AM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You need three conductors so the hot wire from the source passes through the light boxes to the switch. Then the switched wire returns and attaches to each light. The white from the source simply connects to both lights. And the new code requires the white to be present in the switch box also, even if not used.
John
jrclen is offline   Reply With Quote
Old 09-09-2012, 10:48 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
So as jrclen said, you need 3-wire from the first light to the second, then 3-wire to the switch.
Old 09-09-2012, 10:49 AM   #4
Like post #9 in this thread, but with 3-wire to the switch.
http://www.********************/f9/switch-loop-12562/
I see the URL is blocked. Just Goolge switch loop multiple lights and you'll find it. There are tons of diagrams people have very graciously drawn.
Bad elec. solenoid on top of furnace gas valve with spark ignition jerrybrumley HVAC 5 11-19-2011 09:16 PM
Un-used elec wire..hide in wall? GSaunders02 Electrical 4 08-27-2009 07:34 AM
out with elec cooktop, in with gas mathewmarie Appliances 5 11-08-2008 06:58 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Outdoor lights with seasonal elec. run Digger01 Electrical 13 10-30-2007 04:08 PM
