Edison Type Fuse Box - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 08:20 PM   #1
Edison type fuse box
If I have A Breaker box that was installed about 7 years ago, do I still need the edison type fuse box with 15 amp fuses?????? It keeps burning fuses. Now that I look at the fuse socket, the rubber under the center screw is cracked in 4 places. Can someone help?
tapper2a is offline   Reply With Quote
Old 05-26-2012, 08:30 PM   #2
Sparky
Rewards Points: 510
No way to answer this question, if you're blowing fuses there is something obviously connected to the fusebox and would have to be relocated to the breaker panel.
Techy is offline   Reply With Quote
Old 05-26-2012, 08:34 PM   #3
kevinp22's Avatar
Rewards Points: 252
tappa - please post pictures and we can be more helpful
kevinp22 is offline   Reply With Quote
Old 05-26-2012, 08:39 PM   #4
The dryer is connected to both
Old 05-26-2012, 08:43 PM   #5
kevinp22's Avatar
Rewards Points: 252
yikes - my instincts are to recommend my "you might want to call a pro" but until we see pictures ill refrain from saying it. oops i said it anyway
Old 05-26-2012, 08:51 PM   #6
I tried to send pics but as I am not computer literate, They would not go. All I want to know is if I need both? I have someone who can remove it.
Old 05-26-2012, 11:41 PM   #7
Rewards Points: 13,712
15 Amp. is not even close the the size fuse needed for a dryer.
Call a pro before something starts burning.
Old 05-27-2012, 07:16 AM   #8
Rewards Points: 1,512
There may be a loos contact or loose connection in the fuse socket. Any loose connection will heat up and physically burn itself and nearby objects.
The specific fuse socket would have to be either repaired or decommissioned and in the latter case its branch circuit could be moved to the new breaker panel with a junction box just outside the fuse panel if you need to splice on a section of cable to reach.
If you are consistently blowing fuses, then the branch circuits in question may be overloaded. You can get "slow blow" fuses to handle circuits that have a load that draws a lot of amperes for just a few seconds to start up with.
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 04:22 PM
Old Square D Fuse panel problem beadenuser7 Electrical 13 11-22-2010 01:30 PM
100 Amp Fuse - issue - HELP! Leenders Electrical 9 06-02-2008 04:06 PM
Problems with new fuse box for a dryer. needsomehelp Electrical 12 04-10-2008 11:20 PM
Need help with Type T and TL fuses? Fotoguy Electrical 6 03-04-2008 01:08 PM
