Old 10-09-2009, 03:32 PM   #1
Easy THWN question
Running wire to a shed, I need about 130 ft. I already decided just the one 20A line would do (I don't want a subpanel).
Now, 100 ft of that run is inside (the breaker panel is on the opposite corner of the house) then 30 ft of it is outside. What's normal... run the 100ft inside with standard #12 to a box and switch over to THWN and conduit or do the whole thing with THWN (and conduit on the outside).
Piedmont is offline   Reply With Quote
Old 10-09-2009, 03:46 PM   #2
Licensed Pro
Easy THWN question
If you run THHN/THWN it has to be in conduit from panel to panel. I would run 12/2 to where you will exit the house then transition to conduit and individual conductors.
Old 10-09-2009, 05:07 PM   #3
Xtreme DIY'r
Easy THWN question
Yup, I ran NMB to my front, then switched over to conduit for the buried run out front
If you GFCI protect the circuit before going underground you can do 12" depth
I used blank face GFCI's, but you could put a GFCI outlet inside too
Old 10-09-2009, 05:22 PM   #4
300zx's Avatar
Post
Easy THWN question
You could get one of these boxes and put a GFCI in ond then to shed .You will also need a unuse cover you have 1/2 inch con on top fpr gpoing in sofit and bottom for going in the ground
300zx is offline   Reply With Quote
Old 10-09-2009, 05:24 PM   #5
300zx's Avatar
Easy THWN question
Old 10-09-2009, 05:27 PM   #6
Xtreme DIY'r
Easy THWN question
You can do a MWBC (multi-wire branch circuit) - 2 circuits that share a neutral
That way you would have 2 circuits just in case
Just a thought
hrv question indep HVAC 3 07-17-2008 11:39 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 06:48 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
geothermal question robert smith HVAC 2 01-17-2008 09:48 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 01:18 AM
