Easy Sufficiant Service Check? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2013, 06:50 PM   #1
ericmunyon12345's Avatar
Easy sufficiant service check?
Let's say I want to add a couple circuits for a garage or addition. I know the calculating method where you multiply sq. ft. By 3, add 1500 for appliance and laundry circuits, other fixtures... 10000 watts at 100%, and so on (the formula is not my question). Is there a way to get a general idea with a clamp meter. For example, if each leg of a 100 amp service is well under 100 with appliances, etc. turned on, is that a reasonable way to see if existing service is able to handle new circuit(s)? If so, would it follow the 80% safe capacity rule as with branch circuits?
ericmunyon12345 is offline   Reply With Quote
Old 02-20-2013, 06:28 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 464
Yes, you can turn everything on a place an amp probe on each leg.
This will tell you the current draw at that time.
Us the highest rated between the heat and a/c.
There is no 80% rule for the service.
The Following User Says Thank You to jbfan For This Useful Post:
ericmunyon12345 (02-20-2013)
Have I "been had"? Not_My_Area HVAC 21 06-27-2011 06:03 PM
How to properly ground electric service mac70pete Electrical 1 05-25-2011 05:39 PM
Sanity Check For HVAC Service havocwreaker HVAC 19 04-26-2010 12:06 PM
Big electrical mess -- need a sanity check. flashingcursor Electrical 9 04-14-2010 08:48 PM
Service mast options bsperr Electrical 6 12-09-2009 08:48 AM
