Easy Question - PVC Conduit Connection To Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2009, 05:11 PM   #1
Rewards Points: 262
easy question - PVC conduit connection to main panel
Connecting a sub panel in an outbuilding to main service in the house, to a surface mounted 200 amp panel. So far, all the feeds from this main panel enter or exit through the top or bottom punch-out openings, whether in conduit or not. I have a 2" conduit I want to connect, but the only 2" punch-outs are on the side of the box. Is there anything that restricts where you bring in the conduit to the main panel? Thanks, and sorry if this is a really dumb question.
tpagel is offline   Reply With Quote
Old 07-17-2009, 05:31 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 258
What size wires are you running?
You can use an LB into the side od the panel, but if you ars using 2/0 copper, or 4/0 al, it will not be fun.
Are you sure that you do not have a graduated scale of knockouts in the center of the top and bottom of the panel?
jbfan is online now   Reply With Quote
Old 07-17-2009, 05:33 PM   #3
300zx's Avatar
Post
You could use a 2"" lb and a box adapter and a 2 "
300zx is offline   Reply With Quote
Old 07-17-2009, 05:35 PM   #4
300zx's Avatar
Post
Do you have enough room to use a 2"holesaw (If you atempt shut off main)
Old 07-17-2009, 05:37 PM   #5
Rewards Points: 262
I am running 3 #2 copper and a #8 copper ground. The conduit coming from the outbuilding is 2" diameter, and I thought it would be easier to use the 2" conduit all the way to the panel, using the LB's 300Z shows, rather than neck the conduit down. Would three #2's and an 8 even fit in a 1" conduit, much less let you pull them through?
Old 07-17-2009, 05:40 PM   #6
Rewards Points: 262
And do what with it? Drill through the service panel? Yikes!
Old 07-17-2009, 05:45 PM   #7
300zx's Avatar
Post
You would have to go to 1 1/4 you can put 5#2's -1 inch you can only put 3 #2 thats not including your ground
Old 07-17-2009, 05:46 PM   #8
300zx's Avatar
Post
Has been done hundreds of times
Old 07-17-2009, 05:51 PM   #9
jbfan's Avatar
Rewards Points: 258
Might be a few more than that!
Old 07-17-2009, 05:53 PM   #10
Rewards Points: 262
Can't say I would have thought of that. You mind if I make that the solution of last resort though?
Old 07-17-2009, 06:01 PM   #11
300zx's Avatar
Post
You have to be very,very careful Dont know if i would recomend you try but if you do main off and move all other wires out of the way then when you see it getting close to going through slow down so you don't end up with the bit in the panel (I do it all the time sometimes you have no choice but i have been doing it for 15 years. I also have a nockout pounch but way to much money for a hole Maybe a rental shop would let you rent one for couple of hours
Old 07-17-2009, 06:37 PM   #12
Electricians use hole saws and punches to make whatever size hole we need.
Every panel I have seen has up to a 2.5" KO in the bottom center.
Hole saws work great up to 1 1/2". 2" is doable but slow. 2.5" just doesn't want to work. Too much surface area to cut thru.
2" diameter or 2" IPS (trade size)?
I don't think anyone suggested using 1"
You could run it up the side and enter with an LB but it would look like an amatuer did it
220/221 is offline   Reply With Quote
Old 07-17-2009, 07:07 PM   #13
Rewards Points: 262
That one is taken already, and all I have left are 1" diam, though I will check again
This whole house looks like an amateur did it! You should see the framing!
Old 07-17-2009, 07:38 PM   #14
zpm
yeah, right
.... when you see it getting close to going through slow down so you don't end up with the bit in the panel
You could always clamp a piece of 1x where you're drilling as a backstop.
Honey, does this tool belt make me look FAT?
zpm is offline   Reply With Quote
Old 07-17-2009, 07:50 PM   #15
300zx's Avatar
Post
yes very Good idea
Transfer switch to main panel connection i6pwr Electrical 3 01-28-2009 07:09 AM
subpanel feed neutral conductor connection in main panel rtoni Electrical 4 09-17-2008 05:29 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
