Easy Question: How Much Wire To Leave? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-29-2011, 01:34 PM   #1
Rewards Points: 262
Easy question: How much wire to leave?
I am trying to install a new sub panel. I seem to recall an electrician once telling me that once the cable is secured in the clamp going into the panel, to strip the sheathing and leave about one panel height plus one panel width of wire (half the perimeter length) inside the panel to work with. That sound right? Too much? Too little? Doing this today. All quick replies very much appreciated!
tpagel is offline   Reply With Quote
Old 05-29-2011, 01:50 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
that would depend on where the lugs were. what you need is enough wire to reach the connections in a neat manner. If entering from the bottom and the lugs and on the bottom then you need very little. Usually the longest will be the to the ground or neutral bar.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Question about running wire to storage building chris c Electrical 7 01-28-2011 02:33 PM
Wiring a Spa and THHN question. skleinsmith Electrical 29 04-02-2010 11:41 AM
GFCI with 12/2 wire Safety Question Coors Electrical 8 03-09-2010 04:53 PM
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
Electrical wire size question. shawnlee Electrical 11 08-11-2009 06:25 PM
