Easy One Maybe! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 01:33 PM   #1
Easy One maybe!
So I have a brand new gfci outlet with the power hooked on the line side the only thing that is on the load side is a lamp post with a dusk till dawn sensor when the light comes on the gfci trips i checked for moisture and dryed it out with air any ideas on what making it trip? I took the lamp off the load side and put it on the line side for the time being so the light will work as my wife works night shift so it provides some security!
parvinr69 is offline   Reply With Quote
Old 03-12-2013, 01:44 PM   #2
Rewards Points: 2,516
Go to box with the GFCI. Check the wire insulation on the wires leaving the load side of the GFCI.
You may have scraped off some of the insulation while folding the wires back into the box and now they are coming into contact with the box(if box is metal) or a ground.
hammerlane is offline   Reply With Quote
Old 03-12-2013, 02:16 PM   #3
If i bypass the gfci plug and its a grounding issue will it not effect the breaker in the
panel
Old 03-12-2013, 03:21 PM   #4
Check for continuity with multimeter on ohms/resistance.
MisterSteve is offline   Reply With Quote
Old 03-12-2013, 06:40 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It wouldn't trip the breaker if the neutral was damaged and in contact with the ground, but it will trip the GFI.
Is there an easy section to cut out one piece of a baseboard? abefroman Remodeling 2 07-28-2010 03:00 PM
I'll have a bunch of easy questions for you gailquilter2 Electrical 4 05-12-2010 09:00 AM
Easy way to reseal (?) wood floors? boinsie Flooring 3 04-26-2010 08:52 AM
Couple of easy (I think) questions... tigereye Electrical 2 03-01-2010 11:33 PM
Using Easy Board frazierdavidson Flooring 1 01-31-2009 05:29 PM
