Earthing water and central heating pipes
Thank you for your advice and help MgMopar :D
I have looked at the boiler and there is an earth wire in place, so I am assuming that the system is eartherd as all the pipes are metal and are bonded.
Also the water supply to both hot and Cold taps (Forcets) are bonded to each other at the sink/bath end.
I really want to somehow electricaly prove that they are earthed?
I have a thing called a Martindale which will test to see if an English plug socket is wired correctly ie the live wire is in the right hole as with the neutral and earth wires, with out taking the thing off the wall and looking, if they are not then the martindale will show, via 3 led lights, what the problem is.
Im thinking of useing this somehow to test for an earth on the central heating system and the water supply.
Anyone have any more ideas suggestions?
Jack
