Earthing Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 09:42 AM   #1
earthing rod
hi, im digging under the footings to under pin, but there is an earthing rod in place on part of the the excavation site. im only going down roughly 80cm, can i dig around the rod or will i have to move, and if so can i do this myself or call in the electrician?
adamw1 is offline   Reply With Quote
Old 08-05-2012, 04:35 PM   #2
Rewards Points: 1,548
The earthing rod must be fully buried when you are done.
If you are excavating around the earthing rod and the area ill not be backfilled, either pound the rod down nearly flush with the new ground level, or move the rod somewhere else and drive it. (In the U.S. two rods at least 6 feet apart are generally needed to meet code.
You can do it yourself. If you are backfilling around the rod, tamping of the earth is better.
Earthing Northstand Andy Electrical 6 01-25-2012 11:20 AM
Earthing conductor in ground ... John Lesniak Electrical 9 01-15-2012 03:01 PM
electrical earthing karicheti72 Electrical 1 12-27-2010 08:47 AM
Need diagram + procedure for earthing my newly built house in the lawn shaddi Electrical 11 03-09-2009 01:26 PM
Earthing Question bright_spark Electrical 2 07-16-2007 05:21 PM
