Earthing Conductor In Ground ... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 07:26 AM   #1
Earthing conductor in ground ...
I am an electrician but understand that I need to bury a 25mm Earthing Conductor into the ground and then connect it to an Earthing terminal in the house.
What length is required ? How deep?
Regards, John
John Lesniak is offline   Reply With Quote
Old 01-14-2012, 08:49 AM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Normally I bury ground rods at around 8'
plummen is offline   Reply With Quote
Old 01-14-2012, 08:59 AM   #3
Rewards Points: 6,652
Where are you John?
Old 01-14-2012, 09:03 AM   #4
plummen's Avatar
Must be canadian,nobody uses that fancy terminology in nebraska!
Old 01-14-2012, 09:26 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
More likely UK/Euro, Australia, etc. Hints...25mm...Earthing.
Kyle
Old 01-14-2012, 01:40 PM   #6
Rewards Points: 58
John. Since you are an electrician and are obviously not in the US, may I invite you to a forum reserved just for electricians. Here you can get experienced help and help for your particular location. Please visit www.electriciantalk.com and sign up.
Old 01-14-2012, 02:05 PM   #7
Julius793's Avatar
Btw Electrician talk may not welcome them
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-15-2012, 06:32 AM   #8
Sorry folks, forgot to mention that I am living in France
Old 01-15-2012, 07:36 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 784
On dirait que vous parlez de ce que l'on appelle une chaussée Ufer. Ici aux Etats-Unis, vous auriez besoin d'enterrer un fil de cuivre d'au moins 20 pieds de long dans le sol en baisse d'environ 2 '. En d'autres termes, vous creusez une tranchée longue de 20 'et d'enterrer le fil en elle.
Dans la plupart des cas, il est plus facile de conduire deux tiges de cuivre plaqués au sol dans le sol et s'y connecter.
One of our well informed members, FrenchElectrician, lives in France, so hopefully him will chime in soon. Keep checking in to see if he has responded....he will be your best source of information.
ddawg16 is online now   Reply With Quote
Old 01-15-2012, 04:01 PM   #10
plummen's Avatar
I think I recognized the number 20 in that post!
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
