Earthing - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 06:23 PM   #1
Earthing
I am installing 10 lamp posts with 3000 kw of metal lights on each post for a GOLF range . The height of the pole is 15 feet only. The pole is made of Galvanised MS sheets .do I need to install earthing pits
sanjay agarwal is offline   Reply With Quote
Old 09-12-2012, 06:32 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
3000KW -- You need a nuclear power plant.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Speedy Petey (09-12-2012)
Old 09-12-2012, 06:47 PM   #3
Licensed electrician
Rewards Points: 1,020
Your electrician will know what to do.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Speedy Petey (09-12-2012), stickboy1375 (09-12-2012)
Old 09-12-2012, 06:50 PM   #4
thanks. and sorry it is 3KW. one electrician say we need it, another says these are metal posts and very low, thus we dont need it
Old 09-12-2012, 07:46 PM   #5
Electrical Contractor
kbsparky's Avatar
What is an "earthing pit" and what country are you located in?
-KB
Old 09-12-2012, 11:59 PM   #6
Master Electrician
3kw by ten poles. I'd rather not have that hydro bill. Each pole would have to be fed with 8's or bigger depending on voltage drop if they're 120v. I've done a ton of parking lot lighting and your numbers seem a little extreme.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
earthing rod adamw1 Electrical 1 08-05-2012 05:35 PM
2way switch earthing Heve Electrical 2 04-22-2012 09:39 AM
Earthing conductor in ground ... John Lesniak Electrical 9 01-15-2012 04:01 PM
electrical earthing karicheti72 Electrical 1 12-27-2010 09:47 AM
Need diagram + procedure for earthing my newly built house in the lawn shaddi Electrical 11 03-09-2009 02:26 PM
