Earthing - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2007, 06:42 PM   #1
Unhappy
Earthing
I have noticed that where the power comes into my outbuilding the neutral and earth are linked in a small black connector unit, an earth cable (yellow and green ) is then taken from this connector block to a switch casing, power from this switch is then taken to my dwelling house, when I check between earth and live I am getting 240v , is this correct, I did not think this was right but as it was done by the Hydro Electric Board I assumed it to be correct , help!
beggsy is offline   Reply With Quote
Old 08-13-2007, 04:44 PM   #2
Electrical Technician
Hi Bud
Don't worry the reading of 240v between live and earth is what you should be getting.
The Connection you mention is the PME link (Protective Multiple Earth) done by the electricity supplier to ensure you have an adequate earth to your property.
The old system used to rely on you having an earth stake or rod.
Regards
Chris
chrisb271 is offline   Reply With Quote
Old 08-13-2007, 04:55 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Chris, Welcome!
It's great to have an Electrical Tech here from the UK.
You will be a big help.
Old 08-13-2007, 05:00 PM   #4
Hey no problem speedy,i picked the site up from Electricians talk upstairs and thought i would wander down here for a look
Regards
Chris
Old 08-13-2007, 05:48 PM   #5
Well welcome from up there as well.
Earthing Question bright_spark Electrical 2 07-16-2007 06:21 PM
