Earth Grounding Rod Requirements - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 12:07 PM   #16
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Originally Posted by gobug View Post
I just went through this grounding and NEC2011 for my electrical permit in CO. I could not have succeded without the book and my electrician friend.
My building site is on a granite mountain. We tried, but could not pound the grounding rod far enough into the ground. I had the excavator dig a trench near my sub panel. Since it is a sub panel, I only need one grounding rod.
Before I bought the property, it had a house that burned down. The garage is still standing (150ft from the former house and transformer), but no electricity. My permits are to connect the garage and begin the process for a new house.
When the inspector came to inspect the trench and grounding we discussed a bit about the future house. He mentioned a Ufer grounding system. NEC has nothing about this, but I did find some details on line. Does anyone here know about Ufer?
Says who?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-08-2012, 01:10 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You still need two ground rods at a sub panel, or be able to prove less that 25 ohms resistance.
Old 08-08-2012, 01:31 PM   #18
2 grounds
i had just had 2 solar systems installed and both of them each have 2 ground rounds on each. solar company said it is standard practice of their's (in NJ)
JStofik is offline   Reply With Quote
Old 08-08-2012, 02:39 PM   #19
Rewards Points: 79
Sorry, I did place a ground rod in the trench which branched off the trench containing the conduit. The bonding jumper goes from the rod into the sub panel to the grounding terminal bar. It is separate from the cables and ground in the conduit.
gobug is offline   Reply With Quote
Old 08-08-2012, 05:07 PM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
This is the proper picture...
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (08-08-2012)
Old 08-08-2012, 05:13 PM   #21
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
When did they chance supplemental electrode to "augment" electrode??
Speedy Petey is online now   Reply With Quote
Old 08-08-2012, 07:38 PM   #22
E2 Electrician
Its worded like that in the 2005, 2002 NEC editions...
Old 08-08-2012, 08:25 PM   #23
I've always referred to that as a supplemental electrode, like in 250.53.
Old 08-08-2012, 08:36 PM   #24
E2 Electrician
Me too, but its the incorrect wording, as far as the NEC is concerned... but we all get the idea...
aug∑ment/Űgˈment/
Verb:
Make (something) greater by adding to it; increase: "he augmented his income by painting houses"
sup∑ple∑ment (spl-mnt)
n.
1. Something added to complete a thing, make up for a deficiency, or extend or strengthen the whole.
Pretty close definitions if you ask me....
Old 08-12-2012, 12:33 AM   #25
Rewards Points: 175
Thanks for the replies.
So connecting the 2 grounding rods is 6 gauge wire.
Is that solid or stranded?
How deep do you guys usually bury the wire? Or, does the code specify a specific depth?
Flooring Installer. Ecological Restoration Technician. Green Building Enthusiast. Obsessed with insulating and air sealing.
wewantutopia is offline   Reply With Quote
Old 08-12-2012, 01:15 AM   #26
E2 Electrician
#6 cu, bare or insulated, depth is not an issue... I try not to make it a tripping hazard.
Old 08-26-2012, 07:31 PM   #27
Rewards Points: 175
Is it better to use stranded or solid #6 wire for the earth grounding rods?
Old 08-26-2012, 07:32 PM   #28
E2 Electrician
Both are useless, so it doesn't matter.
Old 08-26-2012, 07:33 PM   #29
Rewards Points: 175
wait, what??
Old 08-26-2012, 07:34 PM   #30
E2 Electrician
wait, what??
What? you think ground rods catch lightning bolts and save your house? lol, Home owners insurance is a better investment.
Grounding Switches.... stickboy1375 Electrical 3 08-03-2012 07:59 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 04:05 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
3 phase anyone? Tomkah Electrical 3 01-05-2007 06:18 PM
