Earth Ground Help - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2012, 04:36 PM   #1
Rewards Points: 44
earth ground help
Ok I just purchased a house built in the 50-60's and this is what I found.
the wiring has no ground its just two wire plugs. Someone has put in an earth ground rod and connected the phone and catv to it. I noticed the surge suppressor I have was reading good ground when I knew it should not. I realized the surge suppressor was picking up the the catv as the ground. SO how bad is this ? what problems can I expect ? what is the easiest resolution?
More info
I don't have the money to ground the panel and rewire the house at this time.
The house has full copper pipe water line at least 3-6 feet deep and 50ft to water meter.
there is an antenna and satellite on the roof that is grounded to the conduit that runs through the roof where service was brought into the house
cino72 is offline   Reply With Quote
Old 01-03-2012, 04:48 PM   #2
Julius793's Avatar
Dangerous I would get an electrician to properly ground the main system and the rest do your self.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-03-2012, 04:55 PM   #3
Rewards Points: 44
I was thinking the easier fix would be just to ground the catv and tele to the meter box.
Old 01-03-2012, 05:17 PM   #4
Rewards Points: 1,418
Run a #6 copper wire (#4 for service more than 100 amps) from the panel neutral bus bar (terminals strip) non-stop to the water pipe within 5 feet of the latter's entry into the basement (and before the water meter). (If not already there; omit if the incoming water line is plastic.)
Run a #6 copper wire from the ground rod where the coax cable etc. is attached and down to the basement clamping it onto the first fat ground wire in the most convenient location.
Old 01-03-2012, 05:20 PM   #5
MarginallyQualified
Rewards Points: 2,464
does this mean the receptacles in the rooms?
if so... that's perfectly fine.
"someone" should still have put in a ground rod back in the 50's too.
I'd be surprised if they didn't even if you don't see it now.
And that copper pipe was also tied into the original service as well
...there is an antenna and satellite on the roof that is grounded to the conduit that runs through the roof where service was brought into the house OK
How bad is what?
How about you taking a photograph of the service entrance work
and another of the electrical panel
We'll go from there.
Old 01-03-2012, 05:30 PM   #6
Rewards Points: 44
Originally Posted by TarheelTerp View Post
How bad is what?
I can get some pics have to wait till it warms up its like 17 degrees and almost dark. refering to how bad is what. I think the ground rod that the catv and tele is hooked to has created a loop.
Old 01-03-2012, 05:34 PM   #7
MarginallyQualified
referring to how bad is what.
Have you seen a heavy ground wire in your panel box?
(usually bare copper #6 or bigger?)
Old 01-03-2012, 05:42 PM   #8
Rewards Points: 468
DON"T do that. Get it done the right way call a pro. At the pole i belive they drive 30 feet of groung rod at the pole. Now at the house ??? I am a ham radio op. and i drive 20 feet of copper clad rod for my ground's. Like i said get it done right . Safty First
del schisler is online now   Reply With Quote
Old 01-03-2012, 06:00 PM   #9
Rewards Points: 44
ok here are some pics
Here are some pics some probably not needed but usually more is better. I just got off the phone with guy who lived here and he said catv refused service with out earth ground rod so he put in a rod for them to connect to. I asked where the actual ground rod was for the house and he had no idea. he also said he had no issue for years but my guess is he got lucky. I forgot to add I can take front off panel tomorrow if you need to see inside
Pic of service panel tag
http://i1103.photobucket.com/albums/...-43-09_310.jpg
Service panel A
http://i1103.photobucket.com/albums/...-40-44_798.jpg
Service panel B
http://i1103.photobucket.com/albums/...-40-52_500.jpg
Service pole
http://i1103.photobucket.com/albums/...2/Masthead.jpg
Ground coming from cable box
http://i1103.photobucket.com/albums/...-44-26_236.jpg
Ground rod
http://i1103.photobucket.com/albums/...-44-19_980.jpg
Meter
http://i1103.photobucket.com/albums/...17-44-02_2.jpg
Old 01-03-2012, 06:11 PM   #10
Rewards Points: 44
actually catv grounded to meter box is common practice around here.
Old 01-03-2012, 06:18 PM   #11
MarginallyQualified
Yes, do that.
And stand farther back when you take the picture.
We're looking for something like this to be inside there...
(it may or may not have a bunch of white wires on it too)
Old 01-03-2012, 06:19 PM   #12
Rewards Points: 44
ok ill snap a couple inside the panel tomorrow when i go back up.
Old 01-03-2012, 06:30 PM   #13
Rewards Points: 109
To me the pics don't really help. You need pics of the wiring inside of the panel to see what's going on.
The answer to your question is that you could have serious problems with your current setup. If it's not properly grounded and you lose your neutral then you could be sending a lot of current into your plumbing, appliance housing etc.
Regarding the 2 wire with no ground to room recepticals, you can install special breakers where necessary to make up for the lack of a grounding wire.
If you are comfortable pulling the disconnect then you might remove the panel cover and take a few pics and post.
Daltex is offline   Reply With Quote
Old 01-03-2012, 06:45 PM   #14
MarginallyQualified
I'm 98.6% sure there is no problem at all beyond the original ground wire/rod connection being buried by something that has occurred in the last 55 years.
The other 1.4% suspects that the "something that has occurred" might include it getting damaged and/or mistakenly disconnected from the rod.
Old 01-03-2012, 07:02 PM   #15
Rewards Points: 6,652
It could work, but there is no way to know that the box face is making a clean ground. Proper way is to run a bonding wire from both the telco & catv to a common block, then from there a #8 copper wire goes to the ground rod.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
voltage on ground wire - multiple ground problem? Thaiman Electrical 14 04-02-2011 12:49 PM
FAQ Draft Gigs Electrical 36 03-26-2009 11:54 AM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 11:12 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
