Dyer Receptacle - Connecting The Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2009, 08:59 AM   #1
Dyer Receptacle - Connecting the wires
Hello,
I have a four wire feed (white, black, red, ground) from my electrical panel. I have wired the dryer receptacle box and plugged in the dryer, turned it on and heard an odd noise. I shut off the dryer and realized I had incorrectly connected the red to the neutral and the white to the hot. I made the correction (interchanged them) and the dryer seems to be working fine now.
Should I be worried about the mistake in interchanging the red/white wires and potential damage to the dryer - or is the problem resolved?
Thanks for your help,
Brad
Darb0077 is offline   Reply With Quote
Old 08-06-2009, 09:05 AM   #2
300zx's Avatar
Post
If the dryer is working fine after you fixed the wire on the plug I don't think you should have anything to worry about.Maybe just keep an eye on the first load you do.But i think you will be fine.
300zx is offline   Reply With Quote
Old 08-06-2009, 09:07 AM   #3
The motor and controls saw 240V for a little while. Probably didn't cause permanent damage, but there's no real way to tell right now.
jerryh3 is offline   Reply With Quote
Tags
connection , dryer , receptacle , wire
Req: Help connecting circuit breaker and running wires RickDel Electrical 5 05-26-2009 06:38 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 09:28 AM
20A or 15A receptacle ejlog Electrical 3 02-21-2005 06:29 PM
