DW And GD MWBC - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-13-2012, 01:44 PM   #16
If you are going to go with the MWBC, be aware that the two circuits need to be on "opposing legs" of the panel and a "tie-bar" breaker is required - like a double breaker for a 240 volt circuit.
The tie bar assures *both* circuits are turned off for maintenance. If just one circuit is turned off and the neutral is "messed with" on such a circuit, you could be shocked by touching the neutral!
And the "magic" of an MWBC is by using opposing legs. If both circuits are on the same leg, then the shared neutral can overload and cause a fire.
Be sure to totally understand how this circuit works.
Billy_Bob is offline   Reply With Quote
Old 09-13-2012, 01:48 PM   #17
Thanks Billy Bob. Yeah, I am aware of all that. Just to be 100% sure though, in the last picture hammerlane put up, which wire would connect to which breaker, or does it matter if I am using a double breaker. Would two single breakers be better with a tie-bar?
GOLDBIO is offline   Reply With Quote
Old 09-13-2012, 02:01 PM   #18
Rewards Points: 2,516
doesnt matter as long as they are attached to breakers on opposing legs
hammerlane is offline   Reply With Quote
Old 09-13-2012, 02:21 PM   #19
Resi EC
Rewards Points: 252
The grounded conductor at the switch, isn't required until the 2011 NEC.
Even then (now) if the box can be accessed easily to add one later, its still not required.
I think disposal switch would fall under that exception
Gac66610 is offline   Reply With Quote
Old 09-13-2012, 02:32 PM   #20
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Originally Posted by hammerlane View Post
WHy would you use 12-2 for the switch loop?
There is no purpose to add a third conductor ( either by code or logic).
Coastal South Carolina
rjniles is offline   Reply With Quote
MWBC to Garage Questions benleef Electrical 3 02-22-2012 12:02 PM
Wiring outlets in a MWBC secutanudu Electrical 24 01-07-2012 12:34 AM
MWBC and double taps bryan1282 Electrical 7 01-03-2012 06:25 PM
Line to line load on a MWBC? rjniles Electrical 13 12-09-2011 08:09 AM
Is This MWBC Wiring Setup Legal? DenverBob Electrical 10 10-27-2010 11:36 AM
