Dust To Dawn Timer For LED Outdoor Lighting? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 12:01 PM   #1
Dust to Dawn Timer for LED outdoor lighting?
Just bought some LED lights for the porch, but I realized the new digital timer in wall switch I purchased to replace the on/off says it's for incandescent only. Been looking online, but couldn't find anything specific for LEDs, what should I use?
Thanks,
flyingmachine is offline   Reply With Quote
Old 03-11-2012, 01:43 PM   #2
Rewards Points: 2,516
If you use that timer it most likely will not shut off the LED lights. Your choices are find a timer that is compatible with LED lights or go back to incandescent.
hammerlane is offline   Reply With Quote
Old 03-11-2012, 03:14 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by flyingmachine View Post
....what should I use?
If your wall switch box does not contain a neutral you are stuck with your type of Timer.
Option 1: Put the on/off switch back & leave the lights on all the time. They still use just a tiny amount of power compared to incandescent lights.
Option 2: Leave timer in and add a Motion Light similar to:http://www.homedepot.com/Lighting-Fa...&storeId=10051
The light should draw enough background power to keep your timer working and still not significantly boost the power needed.
Option 3: Add a neutral to your wall switch box so that you can install a more typical clock timer.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-12-2012, 06:24 PM   #4
If you do have a neutral, there are a few options out there. I use the Leviton VPT24-1PZ, but there were a few others I saw when I was looking. Look for one that says it's CFL compatible.
If you don't have a neutral, you can still use a timer switch, but you'll have to change the batteries. Intermatic makes one that installs in the wall and has a button cell battery that has to be changed about every 3 months. Also, there's one out there that just attaches to the wall plate on top of your existing switch and mechanically switches it on and off!
thadsaab is offline   Reply With Quote
Old 03-12-2012, 07:41 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,892
You might want to give it a try and see if it works. There is a decent chance that it will. If not, then a dimmer that is compatible with compact fluorescent will probably handle the LEDs.
mpoulton is offline   Reply With Quote
Wall Timer Wiring Issue sjh5g Electrical 18 02-16-2012 11:57 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 02:16 AM
dust to dawn fixture burns out langrm2 Electrical 3 07-24-2011 09:45 PM
Dust to Dawn contnuously goes off then on at night lkerber7776 Electrical 2 12-28-2010 07:55 AM
Dawn to Dusk Outdoor Light Timer jerevdl Electrical 4 12-02-2010 10:20 PM
