Dust Collector Switch Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 11:49 AM   #1
Rewards Points: 164
Dust collector switch question
I'm looking at a dust collector for my shop that is in good shape, except the switch on it is broken. The switch is 65 bucks, and i'd rather wall mount a switch anyhow, so, is it possible to just wire the dust collector so when its plugged in, its running, and switch the outlet with a heavy duty switch? Any problems doing that?
ryan50hrl is offline   Reply With Quote
Old 07-26-2012, 12:37 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
Probably fine, but we'd have to know the electrical specs of the dust collector to say for sure.
mpoulton is offline   Reply With Quote
Old 07-26-2012, 02:03 PM   #3
Rewards Points: 164
Currently set up to run 110, 14 amps. Its also convertable to 220, but I don't think i'll have room in my box for another 220 circuit. If I found room, could I run it either way off a switch?
Old 07-26-2012, 02:05 PM   #4
Rewards Points: 164
This is the switch I was planning on using if it'll work. Also if this switch will work what's up with there being four terminals on instead of two. Is that for use with 220? If I'm just using 110 do I just use one side?
Dust collector switch question-image-3633667593.jpg   Dust collector switch question-image-3807265352.jpg
Old 07-26-2012, 06:39 PM   #5
Rewards Points: 320
That's a two pole switch. You can use one side of it for 120 volts if you wish.
teamo is offline   Reply With Quote
Old 07-26-2012, 06:42 PM   #6
Rewards Points: 164
What about for 220?
Old 07-26-2012, 06:47 PM   #7
Sparky
Rewards Points: 510
then you use both sides, one hot per side.
Techy is offline   Reply With Quote
Old 07-27-2012, 02:25 PM   #8
If you use it for 120V, you can wire both sides in parallel. This puts half the load on each side and may prolong the life of the switch. Shouldn't really matter though.
Old 07-30-2012, 02:54 PM   #9
Rewards Points: 164
Ok, so i'll be running it on 120, I just don't have the space in my subpanel for another 220 run. If I run to both sides in parallel will that meet code? Or is using one side perfectly adequate?
Old 07-30-2012, 03:11 PM   #10
Rewards Points: 164
Ok, now i'm looking at the box and its rated for 15 amps for 120.....thats not going to work.
Maybe i'll go this route....any problem mounting this in a wall box?
http://www.amazon.com/Woodstock-D415...ZE/ref=lh_ni_t
Sheetrock dust under carpeting in basement... Please help. ben319 Building & Construction 7 09-15-2009 03:35 PM
getting rid of ceiling tile dust notsodiy Building & Construction 12 09-02-2009 11:18 AM
Use stone dust under bricks to form a border around flower bed Curious123 General DIY Discussions 4 08-23-2009 03:41 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Control Dust in Basement Remodel Siamese Remodeling 4 03-19-2008 02:47 PM
