Dusk Till Dawn Light (Pole Light) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2010, 07:53 AM   #16
With just three terminals, I'd think the contacts go between line and load terminals, and the CdS cell is in series with a ~2w resistor or resistance wire which heats a bimetallic switch. With line voltage and light applied the current through the resistor opens the bimetallic switch.
No power and/or no light closes the switch after a time lag.
The resistance from line to N depends on the resistor value and the CdS cell, and is indeterminate.
The contact integrity can be checked: at rated current no more than a 30 mV drop across the closed contacts is good, more than 100 mV is bad.
Separate Single Pole Switches for Ceiling Fan Light and Fan Only estatehomes Electrical 19 01-13-2012 06:13 PM
dusk to dawn light Pudge565 Electrical 5 09-27-2008 09:53 PM
Three way light switches and double pole breaker ShawnColes Electrical 6 04-15-2008 08:25 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
