Dusk To Dawn Sensors - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 08:07 PM   #1
dusk to dawn sensors
I have a dusk to dawn sensor that has worked for years and all of a sudden it started working backwards. It would come on during daylight and go off at dark,any ideas? Thanks
amoth77 is offline   Reply With Quote
Old 01-15-2012, 09:38 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,898
Is it an actual sensor, or is it a timer? If it's a timer ("astronomical time clock") then it just needs programmed. If it's a sensor, then you need to look at where it's pointed and see if there is an explanation for this behavior. Could it be looking at another dusk-to-dawn light, perhaps? Is it in the shade during the day?
mpoulton is online now   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
amoth77 (01-15-2012)
Old 01-15-2012, 09:49 PM   #3
Julius793's Avatar
Replace photocell they go bad all the time
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
Old 01-15-2012, 10:15 PM   #4
Rewards Points: 6,652
Depending on how old it is, it may be time to replace. Those things only work so long before they go bad.
Old 01-15-2012, 11:53 PM   #5
The sensors are dated, so look at the date on the package when you buy a new one. Otherwise you may get one with short life. The sensor is working sitting on the self. You can test the old one with a self powered test light or VOM.
Hardway is offline   Reply With Quote
Do newer dusk to dawn lights cover more area? lighting Electrical 2 11-07-2011 11:46 PM
dusk to dawn light RVS Electrical 2 10-15-2011 07:08 AM
troubleshoot dusk to dawn lighting frmindiana1 Electrical 4 07-25-2011 07:21 AM
Dusk to Dawn Light bacordaro Electrical 4 03-14-2011 01:07 AM
Troubleshoot Dusk to Dawn outdoor light marchem Electrical 7 09-05-2010 02:01 AM
