#1 |
Dusk/Dawn Problem
My 20yo dusk2dawn light went out several days ago. Replaced mercury vapor bulb in it....after turning on the switch it started to light but then went out....called D2D company....was told by a technician that it could be the ballast...bought a new unit with a sodium bulb...after doing the electric connection, the light came on for 4 or 5 nights....was on tonight when we left....when we came home it was out...light is on a 15ft pole in yard...electrical wire is buried under ground, approx 35-40ft from house...never had a problem with this set-up before. Any suggestions would be appreciated....at a total loss right now.
#2 |
Home Remodeler
Dusk/Dawn Problem
Check all your connections and of course your breaker.
#3 | |
Dusk/Dawn ProblemQuote:
1. Make sure breaker is not tripped 2. Make sure you have power to light 3. Check all electrical connections 4. Make sure photoswitch is plugged all the way in |
| Display Modes | |
| Neutral problem, not sure what to do now | BataviaJim | Electrical | 37 | 01-03-2009 12:00 PM |
| Electrical "arcing" problem? | morden5b | Electrical | 17 | 12-17-2008 07:10 PM |
| Stymied by window leakage problem. | Matth3w | General Discussion | 5 | 06-11-2008 07:26 PM |
| Post-Tension Slab Problem Advice/Help | Mike McBride | Building & Construction | 2 | 01-09-2007 02:51 PM |
