Old 01-17-2011, 06:13 PM   #1
Dusk to Dawn with motion sensor will not shut off
I have a Dusk to Dawn Motion light that will not shut off even if reset it. I'm at a loss please help.
Traditional Coach Polished Brass ENERGY STAR® Outdoor Light (H7001)
Glennw1124 is offline   Reply With Quote
Old 01-17-2011, 06:57 PM   #2
Master Electrician
Is there a switch on the fixture that has a 'test' setting on it?
brric is offline   Reply With Quote
Old 01-17-2011, 07:37 PM   #3
Yes It it looks like this
Dusk 6 2 Test
to ( - ) The dash is a switch
Dawn Timer
Also i don't know if this matters but the problem started after i had to replace the bulb it was a clear bulb and i didn't have another like that so i have a regular white bulb in it now.
Old 01-17-2011, 09:38 PM   #4
Some fixtures are intelligent.
If you turn the power on to the light, then turn it off for 3-10 seconds and power it back on, the light will stay on regardless of motion or photo cell.
The solution is to power the light off for about 60 seconds, then power on and it should resume normal operation.
I have several of these and use the "Stay on" feature when we have guests coming over.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-17-2011, 11:02 PM   #5
Ya that's what i thought it was. I do the same thing when guest come over
I'm stumped.
Old 03-05-2012, 08:17 AM   #6
I have the same light with the same problem. We to, switched out the bulb and now it comes on even during the day. I have it on the 2 right now in hopes that means it will only stay on for 2 mins. Even during the day. Did you figure yours out?
hudsonfamily is offline   Reply With Quote
Old 03-05-2012, 08:46 AM   #7
Licensed electrician
This problem was over a year ago. I doubt anyone is still following this thread.
Old 03-05-2012, 08:51 AM   #8
I figured if anyone has updates via email, they may see the post. Since you are an electrician, can you help?
New motion light wont shut off... 68MHJCs Electrical 4 10-09-2010 10:56 AM
Motion light wont shut off 68MHJCs Electrical 10 09-17-2010 10:19 AM
Troubleshoot Dusk to Dawn outdoor light marchem Electrical 7 09-05-2010 02:01 AM
Dusk till Dawn Light (Pole Light) Livewire78 Electrical 15 04-13-2010 08:53 AM
Dawn to Dusk Porch Light problem jaw444 Electrical 7 04-20-2009 04:14 PM
