#1 |
dusk to dawn light problems
I am working on a dusk to dawn mounted street light with the sencor on the top. the light stopped working so i thought it may be the bulb. so i changed the bulb and still no light. took the bulb out and meter test reads 122.5 v . the weird thing is it has power but will not light up. another thing is i don't hear any humming or anything. so i tried the bulb on a light i know works and it fired right up. could it be a bad ground ,loose connection or bad transformer?
#2 |
An old Tradesmen
Moved to Electrical.
#3 |
If you are getting 122.5 v there would not be a transformer? Or is the bulb low voltage and there is a transformer between what you tested and the bulb? It sounds like your sensor might be bad and is not opening the switch.
By the way, I asked the moderators to move this to electrical. I feared it would get lost in appliances.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#4 |
An old Tradesmen
Could be a ballast.
Is this a sodium or mercury vapor light. |
#5 |
Licensed Electrician
You will not get a meaningful reading by metering at the socket if there is a ballast in this fixture.
You need to take the fixture apart and meter the wires coming off the photocell to see if the ballast is getting power. If it is, you are either using the wrong lamp, or the ballast is bad. HID lamps and ballasts must match.
Not a fan of the new layout.
Answers based on the National Electric Code. Always check local amendments. |
| Display Modes | |
| Dusk to dawn light | daltis | Electrical | 22 | 11-26-2012 09:39 PM |
| #6 wire splice to #12 for dusk to dawn | hopskeens | Electrical | 4 | 01-22-2012 03:23 PM |
| dusk to dawn light | julwag | Appliances | 2 | 11-06-2011 03:30 AM |
| Wiring fan and separate light fixture problems | wallyboard | Electrical | 1 | 06-24-2011 01:10 PM |
| Dawn to Dusk Outdoor Light Timer | jerevdl | Electrical | 4 | 12-02-2010 10:20 PM |
