Dusk To Dawn Light Permanently On - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2013, 05:39 AM   #1
Dusk to Dawn light permanently on
I have a dusk to dawn light. After a brief power cut it now remains on all of the time. Even if i switch it off at the switch!! Only way it goes off is if I flip the fuse on the fuseboard. Any ideas?
Wrawby is offline   Reply With Quote
Old 08-24-2013, 07:07 AM   #2
Rewards Points: 12,868
If this is a new problem and you have not been playing with the wiring, I'd start with checking the switch to see if it's making and breaking. Then move onto the sensor.
100% sure it's not on a 3 way switch?
Old 08-24-2013, 07:33 AM   #3
joed's Avatar
Rewards Points: 11,596
Normal operation for those sensor is to switch it on and the sensor operates. Switch it off and on again rapidly and the light stays on until switched off again. That is what happened with the power blink. The Sensor needs to be switched off for 10 seconds to reset it.
If the switch doesn't work then the switch is defective if worked in the past. If it never worked in the past then the switch is wired wrong.
The Following User Says Thank You to joed For This Useful Post:
ToolSeeker (08-24-2013)
Old 08-24-2013, 02:58 PM   #4
Oso954's Avatar
Rewards Points: 442
Is this a dusk to dawn (photo eye) or a motion sensor ?
If dusk to dawn, those switch flipping instructions do not apply.
The light should shut off when the switch is turned off. If not, you have a defective switch, or a wiring problem.
Oso954 is offline   Reply With Quote
Old 08-26-2013, 07:36 PM   #5
Rewards Points: 60
i bought 2 of these and 1 would do the same constantly. Philips said it was a defective product and exchanged it for a new one that worked flawlessly. hope this helps
xclaim is offline   Reply With Quote
Old 08-31-2013, 11:33 PM   #6
Rewards Points: 170
[QUOTE=Wrawby;1233409]Even if i switch it off at the switch!! QUOTE]
Is this the switch on the unit or a wall switch? If a wall switch, chances are a faulty switch.
diyer111 is offline   Reply With Quote
Old 09-02-2013, 04:26 AM   #7
dmxtothemax's Avatar
Rewards Points: 5,098
YES !
It's broken !
dmxtothemax is offline   Reply With Quote
Old 09-02-2013, 11:16 AM   #8
Rewards Points: 150
Turn the breaker off for about 10 minutes and turn it back on. I had one of those lights do that to me
romex1220 is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Dusk to dawn problems ericmunyon12345 Electrical 8 07-11-2013 08:52 PM
Light fan burn out, wall switch backwards later LOYD DUNCAN Electrical 1 09-18-2012 07:49 AM
Dusk to Dawn with motion sensor will not shut off Glennw1124 Electrical 7 03-05-2012 08:51 AM
dusk to dawn sensors amoth77 Electrical 4 01-15-2012 11:53 PM
