DUSK TO DAWN LIGHT Going On For 1/2 Hour Then Off Then Back On. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2010, 03:28 AM   #1
DUSK TO DAWN LIGHT going on for 1/2 hour then off then back on.
Dusk to Dawn light for commercial building , it comes on for maybe 1/2 hour then it goes off for maybe 15 min. then it comes back on . I replaced the photo cell with a new one but it still doing it. I had this problem with others also , some time replacing the photo cell works but not this time.
What do you think it might be , it is starting but you think it might be the igniter?
Jbl15666 is offline   Reply With Quote
Old 11-13-2010, 05:43 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Jbl, Welcome to the Forum
Is your light a High Pressure Sodium ?
Does this Off then back on cycle repeat every night?
Is the light sensor positioned where It can pick up a passing light source?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-13-2010, 05:44 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Hahahaha! I have to say, that typo in the title is one of the coolest I have seen. Please don't correct it.
Sounds like it is getting too much ambient light. They should be aimed so that they do not get much, if any, stray or ambient light form any source.
Having said that, if this is a commercial building you should NOT be doing ANY electrical work AT ALL, unless you are a qualified insured electrician, licensed in the areas you are working.
**You had to fix it, didn't you? I liked "Duck to dawn..." better. LOL**
Speedy Petey is online now   Reply With Quote
Old 11-13-2010, 05:46 AM   #4
Bob makes a good point. Being commercial this is most likely an HID light. A bad ballast or lamp can overheat causing the thermal overload to cut the fixture out.
Again, an electrician can troubleshoot this no problem.
Old 11-13-2010, 06:02 AM   #5
Correct bulb??? Some fixtures have thermal safety cutouts that reset themselves.
The Following User Says Thank You to Just Bill For This Useful Post:
PaliBob (11-13-2010)
Old 11-13-2010, 12:08 PM   #6
Tool Geek
PaliBob's Avatar
Bill may have nailed it.
If the light will not stay on longer than 15 minutes then turns off which means it then cools down before it comes back on then it could indeed be a thermal overload shutdown due to installing a higher wattage bulb.
Question for Jbl, Was the bulb changed before the problem occurred?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-13-2010, 05:42 PM   #7
Rewards Points: 1,192
Need a new bulb...
bobelectric is offline   Reply With Quote
Old 11-14-2010, 12:47 AM   #8
" Euro " electrician
frenchelectrican's Avatar
The first word I catch is commercal really the best move is just get ahold of electrician due safety issue with the HID luminaires.
If HPS that typical for to cycle when the bulb near end of life.
Ditto with some Pulse Start Metal Halides as well
Merci.
Marc
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
Not able to secure vanity light to back plate with any screws luvxyz Electrical 10 10-08-2008 07:18 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 03:52 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
