Dusk To Dawn Light - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 07:48 PM   #16
What is the voltage of the bulb?
Hardway is offline   Reply With Quote
Old 03-11-2012, 08:49 PM   #17
It is 120v.
daltis is offline   Reply With Quote
Old 03-11-2012, 09:18 PM   #18
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by daltis View Post
It is 120v.
Ok you say 120 volts but what type of bulb are we talking about as I posted above MV or MH or HPS or CFL ??
That will make the differnce on how to make the troubleshooting here.
The MV ( common 175 watters ) dusk to dawn luminaire the open circuit is typically about 250 volts it will be mesured at lamp socket or ballast secondary leads.
So if you did read the voltage and come out 120 volts then the ballast is shot.
For other type or other wattage size let us know we will tell you the correct voltage rating on lamp socket.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Hardway (03-11-2012)
Old 03-11-2012, 09:47 PM   #19
It is MV and 175 watts. Thanks.
The Following User Says Thank You to daltis For This Useful Post:
frenchelectrican (03-12-2012)
Old 03-11-2012, 11:06 PM   #20
Merci,
Marc
Sent from phone. Thanks for taking the ball and running with it.
Old 03-12-2012, 05:58 PM   #21
Pas de Problme ( Not a problem )
Merci,
Marc
Old 11-26-2012, 08:28 PM   #22
I am having the same exact problem ,getting 122v and bulb will not fire up. I think it may be a bad transformer or loose ground.
hvac/r- pro1 is offline   Reply With Quote
Old 11-26-2012, 08:39 PM   #23
dont know
Daltis,i am having the same exact same problem122v, new bulb and, will not fire up.maby transformer,or loose ground wire.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Dusk to Dawn with motion sensor will not shut off Glennw1124 Electrical 7 03-05-2012 07:51 AM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 08:19 PM
