Old 04-26-2011, 12:33 PM   #1
Question
duplex receptacle with single pole switch in bathroom
Hi, thanks in advance for any help...I am remodeling my 1950s bathroom. I am replacing the old duplex receptacle (not grounded) with a new grounded one. In the same box is a single pole switch, also being replaced with a new one. I hook everything up (new) and the there is power, but when you turn on the switch the overhead light won't come on. If I hook up all the old, it works fine. There is power, but the light won't come on. I'm so frustrated. Please help! Thanks!
cangert is offline   Reply With Quote
Old 04-26-2011, 01:16 PM   #2
A "Handy Husband"
rjniles's Avatar
One of 2 things:
You wired the new switch wrong
The new switch is defective.
BTW, I hope your new receptacle is GFCI
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-26-2011, 01:45 PM   #3
Is it a combination switch receptacle that fits into a single gang box or is a separate switch and receptacle that requires a 2 gang box?
And does the box(s) have a grounded cable feed?
Old 04-26-2011, 02:26 PM   #4
Yes the receptacle is GFCI.... the switch and receptacle are separate but in the same box.
Old 04-26-2011, 06:46 PM   #5
Scared Electrician
Saturday Cowboy's Avatar
lets have pics
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-26-2011, 07:40 PM   #6
joed's Avatar
Tell us how you connected the wires with the new and the old. We can't see what did from here.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-26-2011, 07:54 PM   #7
Some pics would most certainly help. If you have a ticker or volt meter, check the wiring at the light to make sure power is being sent to the fixture. If there is no power at the fixture when you flip the switch, then you may have mixed up your switch leg. Good luck.
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 04-26-2011, 08:13 PM   #8
Here's how I would wire it, assuming that you have two Romex cables in the box. One would be the feed, the other one to the light.
I would twist the two whites together, along with a pigtail that connects to the silver line terminal of the GFCI.
Then I would twist the power black with a pigtail going to the copper GFCI terminal, then I would loop from this terminal over to a switch terminal.
Finally, I would connect the black to the light onto the other switch terminal.
Old 04-26-2011, 08:14 PM   #9
Then I would twist the power black with a pigtail going to the copper GFCI line terminal, then I would loop from this terminal over to a switch terminal.
Finally, I would connect the black for the light onto the other switch terminal.
Converting a single pole switch to a 3 way Rze Electrical 7 09-13-2011 01:39 PM
Converting a single pole switch to a 3 way Rze Electrical 9 05-02-2011 11:10 AM
How do I provide power to a plug when changing single pole 3 wire to 3-way switch Morris12 Electrical 4 01-05-2011 09:41 PM
Wiring Bathroom fan to dual switch joerob25 Electrical 3 12-15-2010 11:11 AM
installing a single pole switch yummy mummy Electrical 18 04-27-2007 08:06 PM
