Duplex Circuit Breakers - Electrical - DIY Chatroom Home Improvement Forum
Old 12-17-2011, 08:11 AM   #1
Duplex circuit breakers
My control panel indicates that certain slots (5 on each side) can accommodate 1/2" breakers. So you can fit two 1/2" breakers in a 1" slot thus allowing you to add an additional circuit.
Instead of using 1/2" breakers, can I use duplex breakers?
wavewuver is offline   Reply With Quote
Old 12-17-2011, 08:21 AM   #2
Licensed electrician
Rewards Points: 1,464
If I understand your question, typically the two 1/2" breakers are in one physical case. There are 2 internal trip mechanisms.
Old 12-17-2011, 08:36 AM   #3
As I read the label in the circuit panel, it says I can use two 1/2" breakers instead of a 1" breaker. I would rather use a duplex breaker that is 1" and has two trip mechanisms. Just not sure I can.
Old 12-17-2011, 08:43 AM   #4
The breaker you are describing is how you get 2 circuits in a 1" slot.
Old 12-17-2011, 08:46 AM   #5
Yes.....exactly. My question is can I use the duplex breaker instead of two 1/2" breakers? I like the duplex breaker better.
Old 12-17-2011, 08:58 AM   #6
The two 1/2" breaker are connected together in one case. I have never seen a 1/2" breaker by itself without the other 1/2" also.
Old 12-17-2011, 09:00 AM   #7
joed's Avatar
Rewards Points: 12,356
If the breaker is listed for use in your panel then you can use them.
Old 12-17-2011, 09:04 AM   #8
Thanks all......I think the duplex will work. My Murray panel indicates which types of breakers I can use (MP for example). I will get that type.
Old 12-17-2011, 09:05 AM   #9
That's what I thought too. Thanks.
Old 12-17-2011, 10:12 AM   #10
Rewards Points: 742
GE makes 1/2 inch breakers. The GE that are two breakers joined together are two-pole common trip units. BTW, they are tandems, not duplexes. A duplex is a receptacle.
busman is online now   Reply With Quote
Compatible circuit breakers ZOE18K Electrical 1 04-19-2011 11:33 AM
AFCI circuit breakers Skillbuilder Electrical 6 12-11-2010 10:55 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
Sub-Panel or Tandem Circuit Breakers? dgoldsmith Electrical 2 03-08-2008 12:34 PM
Circuit Breakers Unregistered Electrical 4 09-13-2004 08:49 AM
