Dumb Question... What Size Screws For Mounting A Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 08:38 PM   #1
Rewards Points: 79
Dumb question... what size screws for mounting a panel?
I know this is probably a dumb question. Any rules or best practices about what size screws to mount my new panels with? I've got new 42 space and 8 space CH panels to be mounted onto plywood backer boards. The instructions just specify "installer-supplied fasteners".
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 02-28-2010, 08:49 PM   #2
Licensed electrician
Rewards Points: 1,294
I normally use 10x 3/4 or 10x1 sheet metal screws. Depends on the thickness of the plywood.
Old 02-28-2010, 09:12 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
i also like to use a fender washer with each screw
plummen is offline   Reply With Quote
Old 03-01-2010, 01:46 AM   #4
" Euro " electrician
frenchelectrican's Avatar
Most case I use #12X3/4 inch sheetmetal screws and yeah make sure you get fender washer as well that will lock the box in place.
Merci.
Marc
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 08:15 PM
Glass Fuse Panel box question? pouncerw Electrical 4 10-05-2009 10:01 PM
easy question - PVC conduit connection to main panel tpagel Electrical 14 07-17-2009 07:50 PM
Finishing up BoatHouse install - Panel question robertmee Electrical 5 06-07-2009 02:39 PM
Federal Pacific Panel Replacement Question DIYDesign Electrical 5 03-16-2009 12:23 AM
