Dumb Question, How Do You Twist Your Wires Together? - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 04-12-2010, 07:07 PM   #61
Originally Posted by nap View Post
In reference to the tape addition for vibration: if you believe the wirenut is not adequate for the environment, I would suggest a different method of termination, not trying to make an inadequate system work.
and while the tape and scotchkote does generally provide an adequately sealed joint, how about wirenuts that are rated for wet locations?
That would be nice, but in reality, you use what you have on hand. Customers hate paying for travel time. Especially, if they are anxious to get a problem fixed, yesterday!
Old 04-12-2010, 07:32 PM   #62
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, what can I say. I try to keep a decent stock of all the materials I might use in normal work plus, when I am given a job, I try to consider what the job might require so I can grab it before I go to the job.
I can't help it if one does not adequately prepare for a job. I know you can't have everything but until you do, you keep trying to reach that goal.
Old 04-13-2010, 02:50 AM   #63
" Euro " electrician
frenchelectrican's Avatar
This is pretty instering thread about wirenuts and how it done for myself I useally pretwist it so it will hold up better however there are very limited spots that I will put a electrique tape on it only spot is useally found in motor peckerhead { motour junction box }
otherwise I go with Polairs connector for peckerhead box set up.
In Europe wirenut is not super widespread as you think it more common to find choc block aka wire termail barrel connector.
As far for Wago connectors it kinda toss up in France we use a bit but Myself I never like it too much if you want to remove that connector.
Merci,Marc
Dumb Siding question 1610 CUB Building & Construction 4 08-23-2008 04:08 PM
Heil DC90 - AC Wires keithshank HVAC 1 07-31-2008 08:37 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
