Dumb Question? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2012, 02:42 PM   #1
Rewards Points: 150
Dumb question?
Please don't ridicule me for this question because i gotta ask it, OK? Is it in any way OK to pass NM cable perpendicularly through a central heat duct if i send it through a pvc conduit?
The only reason i can imagine this could be all right is that i know that my attic gets way hotter in the summer than heat duct ever will in the winter and I also know that you can do this across a cold air return duct. lil help here? anyone?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 12-22-2012, 04:06 PM   #2
Master Electrician
Rewards Points: 3,678
No...
brric is online now   Reply With Quote
Old 12-22-2012, 04:10 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 770
No and No....
No, it's not a dumb question....and no you can't pass it through the duct....the hot air 'could' damage the wire...
Though I seem to recall a similar thread where it was ok under certain conditions....maybe it was the return duct....
ddawg16 is online now   Reply With Quote
Old 12-22-2012, 04:33 PM   #4
Rewards Points: 12,790
Why not just run it beside it?
I would highly doubt the heat would be the issue, it's where it exits and enters the duct where there could be issues as well as the possiblity of a noise issue with the wires loose in the duct work.
Dumb Question cgoll HVAC 13 03-28-2011 12:24 AM
Dumb question, how do you twist your wires together? Piedmont Electrical 62 04-13-2010 03:50 AM
Dumb HVAC question... 737Pilot HVAC 6 11-03-2008 04:56 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Dumb Siding question 1610 CUB Building & Construction 4 08-23-2008 05:08 PM
