Dumb Girl Question Re Can Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 01-01-2010, 05:54 PM   #1
Dumb Girl Question re Can Lights
I have recessed incandescent can lights in my basement. I am painting the ceiling which is drywall w/ stamped texture. I have to either tape around 8 recessed lights, not that easy, or figure out how to put them back up once they are pulled down.
In my explorations i have pulled two down and there are two tabs with a v on the end attached on opposite sides of the actual bulb fixture. They are tensioned/springy and i am sure are supposed to hold the trim flush with the ceiling. Somehow. I am almost sure the elec installed those after the housing etc and that i should be able to pull those down, paint and put them back up. But i want to figure out how to get the two i have down up before I take all the others down.
I have been reading and there are supposedly slots up there the tabs fit in, okay which slots ? I have tried everything online i can find. There are some that are just slots, some that stick out a little bit and some that are at a slant. None seems to work for me. Is there a tool, a trick, a secret i do not know? I hate to pay an electrician to come out and show me how to do this. I am going to get pictures, is it hard to post here? Do i use photobucket?
Ponygirl99 is offline   Reply With Quote
Old 01-01-2010, 06:04 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You can post pictures with the attachment link above (paperclip) when you post a reply
wirenut1110 is offline   Reply With Quote
Old 01-01-2010, 06:31 PM   #3
All trim rings I have ever seen are held in place by little springs, one end attached to the ring, the other end attached up in the housing. The attach point at the trim ring is similar to as you describe, with a loop on the end of the spring going through the tab. To remove them, I use needle-nose pliars to unhook the spring loop from the tab.
Do you not have these springs?
oberkc is offline   Reply With Quote
Old 01-01-2010, 06:37 PM   #4
I do not have those springs. They are like tabs with a v notch on the end.
Here is a picture http://i197.photobucket.com/albums/a...0/100_6759.jpg
and here is another one of the inside
http://i197.photobucket.com/albums/a...0/100_6761.jpg
Old 01-01-2010, 06:45 PM   #5
Rewards Points: 161
If I am not mistaken, those tabs are just pushed in toward the light and the whole trim ring is pushed into the housing. The outward pressure from the tabs keep the trim ring in place.
paul100 is offline   Reply With Quote
Old 01-01-2010, 07:58 PM   #6
So do i push them up or down? Or in?
i have tried just any ole where and it does not seem to grab like it should and it gets off center from the hole.
Old 01-01-2010, 08:12 PM   #7
Rewards Points: 161
Just push them up and toward the center of the trim ring. Then push the trim ring into the fixture. Once pushed up just move the ring around until it is centered.
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 05:20 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Exterior Carriage Lights - Box Question tkdcal Electrical 3 06-02-2006 07:40 PM
