Old 10-23-2012, 08:40 AM   #1
Dumb Dimmers
I have an Aspire master and Remote dimmer switches wired correctly to 5 LED lights 55 watts each. Both of them dim the lights up and down but the problem is when I shut them off. They dim down fine, shut off, and then the 1st and last light comes back on very dim. Seems to me that the power to the lights is not completely shutting down. Bad master or bad remote maybe. Other than what I described they work fine, no noise either. Help if you can, thanks.
Smarbada is offline   Reply With Quote
Old 10-23-2012, 11:34 AM   #2
joed's Avatar
Dumb Dimmers
Some of those device draw a small trickle current through the fixture to operate in place a neutral connection. That small current is not a problem for the old style incandescent lamps. However for CFLs and LEDs it can make them blink or come on dim. Usually one old style lamp on the circuit will cure the problem.
Do not PM with questions that can be asked in a forum. I will not respond.
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 02-01-2012 12:34 AM
Help!! So confused on wiring dimmers! Skylaa Electrical 19 12-12-2011 10:59 PM
Help with Lutron Maestro IR dimmers jkr77 Electrical 5 02-28-2011 09:38 AM
Too many dimmers? MikeVila Electrical 6 11-30-2010 07:46 PM
leviton vizia dimmers Thomas Rice Electrical 2 03-14-2009 07:16 AM
