Duct Seal On Rear Meter Pan Knockout? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 06:51 PM   #1
Rewards Points: 508
Duct Seal on Rear Meter Pan Knockout?
We're in the process of putting in a meter pan for underground service at my house. The electrical inspector reccommended that we use a rear knockout for the service entrance. I was under the impression I should use a protective bushing or something on the knockout, but the guy at the supply house said most people use duct seal. Can anyone confirm this practice?
benjamincall is offline   Reply With Quote
Old 01-20-2012, 07:07 PM   #2
Licensed electrician
Rewards Points: 1,240
You are going to need to use a cable or conduit connector and a bushing.
The duct seal would stop the flow of air through the conduit, if used.
Old 01-20-2012, 07:16 PM   #3
Rewards Points: 508
I think the guy was saying that people just lined the sharp edge of the rear knockout with duct seal.
So, I would use a clamp-type connector for the 4/0 SEU running out the rear knockout?
Old 01-20-2012, 07:33 PM   #4
Yes, you need a connector for the SE-U.
Old 01-20-2012, 07:39 PM   #5
Rewards Points: 508
Thanks! Most service entrances I see use a conduit body. I was a little unclear what I should do based on the graphic below:
Old 01-20-2012, 07:42 PM   #6
How does the cable run after leaving the socket? Where is the panel in relationship to the socket?
Old 01-20-2012, 07:46 PM   #7
Rewards Points: 508
Panel is within about four feet, down in the basement, and on a perpendicular wall. The inspector considers this location as close as practically possible, and won't require conduit. The SE-U will go down a stud cavity, through the bottom plate, and along the rim joist.
Old 01-20-2012, 07:52 PM   #8
I might consider exiting the bottom of the socket and down and turn into the rim joist.
benjamincall (01-20-2012)
Old 01-20-2012, 08:34 PM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
I personally would say that inspector is nuts and run it in conduit anyway!
All it takes is 1 stray nail down the road when then area has been covered and forgotten to cause a world of problems,and there wont be nothing to protect it from happening.
Not to mention there wont be any way to minimize the damage or shut it down like a home run going through the joist since theres no breaker involved.
plummen is offline   Reply With Quote
Old 01-20-2012, 09:32 PM   #10
Rewards Points: 508
I'll just leave a pictorial guide of how to pull the meter for the next owner.
Old 01-24-2012, 11:40 AM   #11
Rewards Points: 508
To the original question, what type of protection does one typically use on the the rear knockouts of a meter pan when not running conduit? A terminal adapter with a lock nut and a protective bushing or a clamp style connector?
http://www.amazon.com/Cantex-5140108.../dp/B000BQURZG
http://www.amazon.com/Morris-Product...7421951&sr=1-3
Old 01-24-2012, 12:34 PM   #12
Electrician
SD515's Avatar
Rewards Points: 504
A SE clamp and a bushing if you’re running SE cable out of it. You can’t just line the raw-metal hole with duct seal. You need the clamp to protect and secure the cable.
Kyle
Old 01-24-2012, 12:39 PM   #13
That male terminal adapter is for use with PVC conduit.
SD515 (01-24-2012)
Old 01-24-2012, 04:59 PM   #14
Rewards Points: 508
Since the conduit is not underground (wet location), I should be OK placing the SE-U in conduit, correct?
Old 01-24-2012, 06:07 PM   #15
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would also put the wire in conduit from the meter socket to the breaker panel. And make sure you put an expansion joint on the pipe going from the ground to the meter socket. It's 20 bucks well spent and required in some areas.
rrolleston is offline   Reply With Quote
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 07:25 PM
Is My Electric Meter Correct: Conclusion. fcfcfc Electrical 0 10-03-2010 07:00 PM
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 10:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 07:35 AM
