Hi everybody.. im a new member on the board, but i have been stopping by for years now, and always found this an excellent helpful resource. Please help me with my first question..
Is it possible to wire a motion detector with 2 sources of electricity? First source would be from a switched set of wires which power the light directly (bypassing the motion sensor). The second source would be from a live set of wires which power the motion detector which will act as a switch for the light. With this configuration, the motion sensor will always be on at night, but you have the option to always be able to turn on the light from the wall switch regardless of something tripping the motion sensor. From what i have seen, on a normal circuit, if you flipped the switch on (while on the motion sensor setting) and there wasnt motion outside, the light wouldnt go on. The only weird thing i could think of with this is that you wouldnt be able to turn the light off if there was motion detected, and when the switch is on, and motion is deteced, it would be getting power from 2 wires (which is the same thing as being powered by a thicker wire, right)?
idk.. in theory it whould work, but i dont see why nobody else has been writing about it online.
If this works, then comes the ability to wire more lights into the circuit, and add more motion sensors.
Thankis
Thankis
