Old 03-17-2008, 04:44 PM   #1
tonyBagadonuts's Avatar
Dual Wattage Elements
I have a GE water heater with a 4500/3380 watt rating element. Can I replace this with a standard 4500 or can I go to a lesser wattage?? Tank only serves a kitchen and 1 vanity so not a high end user of hot water.
thanks
tonyBagadonuts is offline   Reply With Quote
Old 03-17-2008, 04:53 PM   #2
Electrician
thanks
how many gallons is this?
chris75 is offline   Reply With Quote
Old 03-17-2008, 05:28 PM   #3
This is a 40 gal tank and it is a 2 element tank. Both elements show the dual wattage of 4500/3380.
Old 03-17-2008, 06:05 PM   #4
" Euro " electrician
frenchelectrican's Avatar
the reason why you see the dual wattage marking on the water heater element due two diffrent voltage running in the system
the 4500 watt marking is on 240 volts system while the 3380 watts is used on 208 volt system.
that element with dual wattage rating it dont hurt to run either 240 or 208 volts
Majorty of the resdential area useally are 120/240 v system but there are some spots that used 120/208 v system [ that is network feed from 3 phase supply ]
Merci,Marc
Old 03-17-2008, 06:14 PM   #5
That makes sense........ Thanks much Marc
dual switch ktrydancer Electrical 2 11-13-2007 10:11 AM
Dual sensor Dual head motion light? sandyman720 Electrical 1 09-26-2007 07:40 PM
Installing Water Heater Elements Steve VA Plumbing 1 06-15-2007 11:58 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
Heat elements making noise helpless handyman HVAC 17 12-06-2006 03:49 PM
