Dual Wall Oven Rated At 30a, Use 30a Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 08:17 PM   #1
Rewards Points: 150
Dual wall oven rated at 30a, use 30a breaker?
I know this is a dumb question, but is 30a the proper breaker to use? This is a 220v unit of course. I am replacing an old wall oven and want to double check!
Thank you.
240sx4u is offline   Reply With Quote
Old 07-20-2011, 08:18 PM   #2
Rewards Points: 6,652
Use what the manufacturer recommends.
Old 07-20-2011, 11:36 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Check with the manufacter specs I know with single wall oven typically use 20 or 30 amp circuit but for double wall oven units I know they take either 30 or 40 amp circuit so check it out ahead before you get the new wall oven to make sure the wiring is good shape.
If you have alum conductors pay attetion to the connection they are little more flicky with it we will help you in little bit but before we can go further let us know if you have copper or alum conductor.
I know alot of older place useally have 3 conductors in place but if you have to run a new circuit due the double wall oven require larger circuit then run full 4 conductor { hot et hot et netural et ground }
Merci,
Marc
HVAC duct through a fire rated wall elmaur Building & Construction 2 05-30-2011 12:22 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-02-2011 11:09 PM
only 1/4 inch of frame & wall on each side of wall oven tentativentexas Appliances 1 09-27-2010 06:56 PM
What size breaker for 4100 watt wall oven? romexican Electrical 3 09-15-2009 09:34 PM
