-   -   A dual switch question (http://www.diychatroom.com/f18/dual-switch-question-124803/)
anatoly52 11-27-2011 08:34 PM
I need to install a dual switch for fan/light fixture.
I did this kind of work before, so I do not understand what I did wrong.
I have a red/black/white/green wire running from the fixture box
to the dual switch (the switch is not faulty, I checked it).
I connected the black hot wire to the switch per instructions (on the right, where the bridge for two circuits is).
I connected red and black wire to each of the screws on the left of the switch per instructions.
I went to the garage and turned the breaker on. No short.
I went upstairs and turned swithes on. No short.
I thought everything is OK, so I took electrical tester and tried to check
that both fan and light circuits work.
What happened is that as soon as I contacted black and white wires with my tester, a spark occurred and a contact on my tester partially melted.
Does anybody know what caused it?
Thank you.
oberkc 11-27-2011 08:44 PM
tester on the wrong setting?
contact white and black with same tester probe?
anatoly52 11-27-2011 08:49 PM
The tester is a simple one, two wires with a led light in between. No settings. I used it before. After a contact partially melted I used the tester on the outlet, it works.
I did not contact white and black with the same probe. In fact, after I had this happened, I rechecked the wiring, and tested again. Same result.
a7ecorsair 11-27-2011 09:16 PM
Where is power fed for this circuit? Is it fed to the ceiling box or to the switch box? You say there is a blk, red, and white wire at the switch. Do they all come from the same cable? Is there any other cables in the switch box?
anatoly52 11-27-2011 11:32 PM
The power is fed to the switch box.
The power comes with black/white/ground wires.
The dual switch feeds both black and red wires coming from the fan/lights.
There are no other wires in the box.
The set up is pretty simple and standard.
Thank you for reply.
frenchelectrican 11-27-2011 11:58 PM
That fine so far but the question is what you did with the white conductor did you wirenuted together ?
Bon.
Bon.
was the fan et light is working ??
Did you have a nick in the conductors ? if so that will cause to temporly short it out and do you have metal junction box or plastique box ?
Thank you.
See my answer in bleu colour
