Dual-switch Light Driving Me Nuts - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-18-2010, 05:18 PM   #16
joed's Avatar
Rewards Points: 12,878
The ballast is probably above that metal plate. How you get to it, I can't say. Can you post a slightly wider shot of the unit.
There are wires on that socket that attach to the ballast.
Old 02-18-2010, 05:26 PM   #17
prj
The wires coming out of the socket go to a junction box next to the hole in the ceiling. Just spoke with the builder's electrical sub and they say there is definitely a transformer behind the junction box. He told me how to get it out and replace it but it's a 13W and he said a new one might be hard to find. He suggested just bypassing the transformer and replacing the can with a newer model with a built in transformer.
How I'm going to do all that through a 6" hole, when I can't really see much in there, is another story.
What an odyssey!
prj is offline   Reply With Quote
Old 02-20-2010, 08:57 PM   #18
prj
Follow-up:
I was able to by-pass the transformer (cut wires and re-wired inside the junction box) and re-used the existing wiring directly into can, where I replaced the socket shown above with a standard round socket and screw-in 25watt compact fluorescent. Works fine. Cost me $10 for a new can from which I extracted the screw-in socket plate. My local Lowes store had no can fixture with an attached transformer or any replacement transformer like what I removed.
Thanks for all the help.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
