Old 11-13-2007, 01:22 AM   #1
dual switch
I have a single switch that controls the bathroom light. I would like to change the single to a dual switch and add another light. I will have 9 wires 3 black 3 white 3 green. How would I wire this situation?
ktrydancer is offline   Reply With Quote
Old 11-13-2007, 07:52 AM   #2
waiting for spring
arichard21's Avatar
dual switch
okay, i am going to assume for a minute. lets assume that of the 3 cables coming into the box, 1 is incoming power, and the other 2 go to the lights.
all the neutrals should get wire nutted together.
the grounds should be pigtailed with 2 leads coming out, 1 going to each switch
the incoming hot should be pigtailed with 2 leads coming out, 1 to each switch
the 2 remaining hots should go 1 to each switch.
arichard21 is offline   Reply With Quote
Old 11-13-2007, 10:11 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
dual switch
If you are dealing with a single gang box then you would be talking about this type switch......one side of the switch is a common side both screws are connected with a tab. The side shown is where the two blacks going to the switches will be connected. The incoming hot will go to the common side getting power to both switches. All neutrals (whites) joined together. Ground the switch with a jumper to the box (if metal) and to the incoming grounds. This is the surest grounding, code does allow for other options but for diy this is the best method IMO.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
