-   -   dual switch (http://www.diychatroom.com/f18/dual-switch-13365/)
ktrydancer 11-13-2007 12:22 AM
dual switch
I have a single switch that controls the bathroom light. I would like to change the single to a dual switch and add another light. I will have 9 wires 3 black 3 white 3 green. How would I wire this situation?
arichard21 11-13-2007 06:52 AM
okay, i am going to assume for a minute. lets assume that of the 3 cables coming into the box, 1 is incoming power, and the other 2 go to the lights.
all the neutrals should get wire nutted together.
the grounds should be pigtailed with 2 leads coming out, 1 going to each switch
the incoming hot should be pigtailed with 2 leads coming out, 1 to each switch
the 2 remaining hots should go 1 to each switch.
Stubbie 11-13-2007 09:11 AM
If you are dealing with a single gang box then you would be talking about this type switch......one side of the switch is a common side both screws are connected with a tab. The side shown is where the two blacks going to the switches will be connected. The incoming hot will go to the common side getting power to both switches. All neutrals (whites) joined together. Ground the switch with a jumper to the box (if metal) and to the incoming grounds. This is the surest grounding, code does allow for other options but for diy this is the best method IMO.
http://assets.twacomm.com/assets/194...ages/18370.jpg
