Dual Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 06:17 PM   #1
dual light switch
I am replacing a light fixture that is run on a dual light switch. Out of the electical box were 2 white wires that are twisted together, a black wire and a grounding wire. I hooked up the fixture, white to white, black to black and ground to gtround. The issue is now the dual light switches operate independantly. In other words, the top switch will turn the fixture off and on, the lower switch will turn the fixture on and off but if I turn the light on with the top switch, I cannot turn it off with the lower switch
Karen Padden is offline   Reply With Quote
Old 06-03-2011, 06:29 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
Are you sure it ever worked like that?
A dual switch it used to control 2 loads from the same supply.
Old 06-03-2011, 07:40 PM   #3
Yes the old light fixture was operated from both switches.
Old 06-03-2011, 08:24 PM   #4
I=E/R
a7ecorsair's Avatar
What do you mean by dual light switch? Do you mean a three way switch? A three way switch setup would be one switch at one side of a room and another switch at the other side with both switches controlling the same light.
a7ecorsair is offline   Reply With Quote
Old 06-03-2011, 08:34 PM   #5
Licensed electrician
Rewards Points: 1,508
I suspect the feed is not on the common terminal.
Old 06-03-2011, 10:29 PM   #6
I guess I do mean a 3 way switch, 2 switches at either end of the hall work one light
Old 06-04-2011, 08:03 AM   #7
I=E/R
a7ecorsair's Avatar
This makes sense now.
In your first posting:
Is this the box where the old fixture was attached? Is this how the wiring was before you touched anything? Things don't add up. You have two white wires but only one black and one ground. You'd better take another close look inside that box.
Old 06-04-2011, 09:46 AM   #8
The original fixture was wired 33 years ago and the original fixture was connected to the 2 white wires Oops there are 3 white wires , the black wire and the grounding wire. There are additional wires inside of the electrical box, but they were not connected to the light fixture we took down. Why would both switches work the fixture (only not together), could it be the light switch also
Old 06-04-2011, 10:40 AM   #9
I=E/R
a7ecorsair's Avatar
Somehow you didn't connect the new fixture to the same wire configuration that was used with the original fixture. I'd guess that two of the wires are part of the travelers that run between the two switches.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Blown Light Switch ogrenjr Electrical 3 03-01-2010 03:42 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
no power going to the light switch baseballfan Electrical 18 09-08-2008 05:35 PM
Problem changing light switch grgryl Electrical 14 08-10-2008 01:26 PM
