Drywalling Around An Existing Panel... Any Code Issues? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 02:43 PM   #1
Rewards Points: 79
Drywalling around an existing panel... any code issues?
Currently, my main service panel is attached to a plywood backer that's attached to furring strips directly on the basement wall. The rest of the wall is covered with wood paneling attached to furring strips.
I'm wanting to take down the paneling and put up some rigid foam insulation between the furring strips and cover with drywall. Obviously, I'm not going to bother the existing panel, so the drywall will be flush with the plywood backer. Any problems with that so far?
Step 2 will be to install a new sub panel next to the existing panel. This will be attached to a plywood backer on top of the new drywall, so will be raised off the wall further than the current panel.
Any problem from a code standpoint doing either of these?
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 12-28-2009, 03:09 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
I would install the sub the same as the main panel, then do the drywall.
You're way works also.
Old 12-29-2009, 12:10 PM   #3
Rewards Points: 58
I agree that you should install the sub panel the same way. It will look much better. If you cannot or do not want to, you can use one of these for the sub. They are available in most all standard trade sizes.
wiring from existing panel to new garage al99m Electrical 8 07-29-2009 09:42 PM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
breaker panel question chadvavra Electrical 11 08-10-2007 10:20 AM
Drywalling an existing outlet? 1nonly Electrical 16 03-05-2007 02:54 AM
Pigtail inside panel box. Code allowed? KUIPORNG Electrical 7 08-22-2006 04:45 PM
