Drywall Screws - Electrical - DIY Chatroom Home Improvement Forum
Old 02-11-2015, 07:02 PM   #1
Rewards Points: 225
drywall screws
Trying to avoid hitting wires or anything else behind walls. If a drywall screw hits the wire will it automatically trip the breaker or can the wire continue yo have power? Thought of using a non contact voltage tester and touching the screw to see if there is power? Also, if the wire does not have power how can one tell? Any tools that could help? I know that there are plates to protect the wires and the wires should be far enough back but I have opened many walls and there have been no plates and the wires very close to the drywall. Thanks for your help.
gt1935 is offline   Reply With Quote
Old 02-11-2015, 07:23 PM   #2
Licensed electrician
Rewards Points: 1,622
The screw would need to hit the hot and another conductor or a grounded surface before tripping the breaker.
Old 02-11-2015, 07:55 PM   #3
Rewards Points: 469
Ive pulled 40 year old wiring out with a nail thru the center but never shorted and thats why they invented afci they may short out right away or take years to catch your house on fire
Jnaas2 is offline   Reply With Quote
Old 02-12-2015, 03:25 AM   #4
dmxtothemax's Avatar
Rewards Points: 5,362
Use the shortest possible screws
And allow enough clearence behind walls
dmxtothemax is offline   Reply With Quote
Old 02-12-2015, 06:37 AM   #5
Rewards Points: 1,514
Holes for wires in studs are supposed to be at least 1-1/4 inches behind the stud edge and this means at least 1-3/4 inches behind the drywall surface. If the hole absolutely positively has to be closer to the wall surface then you need a "nailing plate" over the stud edge that will inhibit the placement of a screw at that location.
You would then be able to use 1-1/2 inch drywall screws without any problem.
It is possible for the cables to waver a little, coming closer to the wall surface between studs. But more often than not, a screw will push the wire back rather than penetrate it.
Drywalls crews have very little holding power between studs. Toggle bolts work better and also do not have sharp points making penetrating the wire even less likely.
If the screw penetrates one conductor in the cable, no short will occur althoug it is possible for the screw to become energized.
Drywall screws popping en masse creoena Drywall & Plaster 20 08-29-2012 01:16 PM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 08:15 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Cutout in drywall around sink coutertop bananey Drywall & Plaster 4 05-04-2011 04:47 PM
Drywall Screws Rusting? rick112 Drywall & Plaster 17 03-29-2011 10:57 AM
